Thames Anglers' Conservancy Members Forum
TAC Members-Only Forum
If you have arrived here and not yet signed up as a member, then please first join at http://t-a-c.actionboard.net/register using your real name.
Forum Membership is with Real Names only.
Please create a Username that is your First Name and Surname eg. "Joe Bloggs"
(This will save our Admin team the need to contact you about changing it)
http://rivertac.org/membership
HomeHome  TAC Home PageTAC Home Page  SearchSearch  FAQFAQ  RegisterRegister  Log in
Navigation
Search
Display results as :
Rechercher Advanced Search
» Eel Trap Clean Up/ training 5th May 2018
Mon Feb 12, 2018 5:04 pm by patrick barker
» Riverfly & Clean-up Donkey Woods Saturday 18th Nov 2017
Sat Dec 23, 2017 1:02 pm by Ed Randall
» Biggest fish of all book
Fri Dec 22, 2017 5:43 pm by Adrian Hoare
» Wandle Trust - eel pass installation - call for volunteers
Thu Dec 07, 2017 8:53 am by Ed Randall
» Outfall Safari across London - call for Volunteers!
Thu Dec 07, 2017 8:47 am by Ed Randall
» Fishing the Thames at Medley
Thu Nov 02, 2017 2:33 pm by Trevor Rowe
» Thames Semi-Tidal Draw Off 2017
Fri Oct 20, 2017 9:08 pm by Ed Randall
» Eel Trap Results 2017
Tue Oct 17, 2017 6:07 pm by patrick barker
» Fish-swallowing Angler "lucky to be alive"
Sat Oct 14, 2017 8:01 am by Ed Randall
» River Mole polluted at Horley
Fri Oct 13, 2017 8:52 am by Ed Randall
» Petition to stop the export of elvers
Thu Sep 21, 2017 2:16 pm by Ed Randall
» Riverfly Training ~ Hogsmill ~ 30th Sept 2017
Sat Sep 16, 2017 6:56 am by Ed Randall
» Monster fatberg in Whitechapel
Tue Sep 12, 2017 1:40 pm by Ed Randall
» Radio 4 ~ Macquarie: The Tale of the River Bank
Tue Sep 12, 2017 12:28 pm by Ed Randall
» Thames TideFest 10th September 2017
Tue Sep 12, 2017 9:00 am by John LeSurf
» Invitation to the 2017 Eel Forum ~ 17th October
Sat Sep 09, 2017 8:32 am by Ed Randall
» Do you recognise any of these men?
Sat Aug 19, 2017 8:44 pm by Ed Randall
» Roads closed everywhere ~ July 29th/30th ~ bike race
Wed Jul 26, 2017 9:17 am by Ed Randall
» Better access to free Thames fishing in Reading
Fri Jun 16, 2017 10:08 am by Ed Randall
» Eel screens on Water Works intakes
Tue May 23, 2017 10:26 pm by Julian Jones
» River Thames Conditions - Quick Dial Numbers
Sun May 21, 2017 10:00 am by Ed Randall
» Ap[ril showers? If only! Drought beckons...
Thu May 04, 2017 6:56 pm by Ed Randall
» Abbey river this Saturday (12/5/2012)
Thu Apr 27, 2017 4:41 pm by Ed Randall
» Molesey Eel Monitoring Training ~ 29th April 2017
Mon Apr 24, 2017 11:12 am by David Harvey
» Thames Water fined a record £20m for River Thames pollution
Fri Mar 24, 2017 1:54 pm by Stephen Bond
» Crane Riverfly Training ~ May 6th 2017
Thu Mar 16, 2017 9:08 am by Ed Randall
» TAC visit to Tideway Tunnel Exhibition in Parliament
Wed Mar 15, 2017 7:32 am by John LeSurf
» "Citizen Crane" project - sampling dates
Thu Mar 02, 2017 4:24 pm by Ed Randall
» Egham & Stains bankside enhancement followed by brewery trip
Sun Feb 19, 2017 6:27 pm by Ed Randall
» SE Rivers Trust needs help on Hogsmill
Tue Feb 14, 2017 2:23 pm by Ed Randall
Angling Data View
River Levels
UK Map
Thames Tides
Share |
 Eel Trap Results 2015 !
Go down
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
AuthorMessage
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Sun Jun 07, 2015 4:54 pm
Very good news and great to see you Smile
Here is a pic of the little blighters cheers
http://Rivertac.org
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 12, 2015 9:38 am
Hey chaps
I am struggling for time tomorrow, is anyone heading down ?
http://Rivertac.org
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 12, 2015 1:58 pm
I can go down sat. Morning probably about 10.30. Gonna be on my own I think.
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 12, 2015 2:28 pm
Okay thanks mate, sorry am a bit challenged in terms of time this weekend
I am going to drop by midweek as its warmer and should be looking a 2 checks now.
http://Rivertac.org
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 12, 2015 5:10 pm
Ok nice one. I've got next week off for angling purposes so will probably spend some time at the weir chucking feeders at the slimy things.
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Sat Jun 13, 2015 1:05 pm
Result today folks 49 of the wriggling variety and 1 crabster. Think Eds got some photos that he can post when he gets a mo.
Ed Randall
Male Posts : 3224
PostSubject: Re: Eel Trap Results 2015 !   Sat Jun 13, 2015 3:21 pm
The large syphon had stopped, here are the instructions on how to re-start it
1. Make sure that the top end of the syphon hose is held under water.  It should be wedged pointing downwards between the "H" of the girder there. Give it a shake in case a leaf or something has been sucked in & blocking it.
(awaiting photo)
2. Fetch the hand pump from the plastic box in the lockkeepers hut
3. Screw the white adapter into the end of the large syphon pipe
(I forgot to take a photo with the syphon stopped - if its running any worse than this it might have air inside and be worth re-priming it)
4. Adapter screwed in to large syphon pipe.
5. You are going to be pumping water from the trap BACK UP the syphon.  So the other red hose is going to suck water in to the pump - ensure that it is kept under water in the trap.
This has 2 benefits: -
(a) it will push any debris which has been sucked into the syphon from the top, back out the way it came
(b) it's the only way of priming the syphon which actually works - the pump is not strong enough to suck the air downwards nor push it downwards from the top
You'll likely need to pump quite a few times, maybe 50 pumps.  You should firmly hold the base of the pump to prevent the pressure hose being ejected from it and the base of the pump being forced off the cylinder.  Try not to break it, it was only a cheap thing and won't take much abuse.
6. You can tell by feeling the weight of the syphon hose (further up at the top of the weir) when all the air has been ejected.  Unscrew the white adapter and the syphon should be running, like this
7. Drain any water out of the pump and hoses before putting it back in its box.
TAC Secretary
Angling Trust member #61385
Ed Randall
Male Posts : 3224
PostSubject: Re: Eel Trap Results 2015 !   Sat Jun 13, 2015 3:31 pm
Eel photos from 13th June 2015
Mistress of measurement!
TAC Secretary
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Mon Jun 15, 2015 8:14 am
Good work chaps, Ed noted about the hand pump Smile
http://Rivertac.org
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Tue Jun 16, 2015 8:10 pm
Popped down after work and another 30 were recoreded. Very Happy
If anyone is around Thursday please feel free, lots coming up, the I will be down for 10am on Saturday.
http://Rivertac.org
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 19, 2015 1:33 pm
Going to pop down there tomorrow about 10 for coffee at shawns. Will meet anyone else there who is coming.
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 19, 2015 1:37 pm
See you there mate
http://Rivertac.org
Barry Kneller
Male Posts : 191
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 19, 2015 7:01 pm
Every time I see a photo of these little beggars I can't help imagining a a hook and a big Perch or Chub................. Twisted Evil
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Sun Jun 21, 2015 10:19 am
Dave, Nicola and myself went and checked the eels yesterday there were 12 no crabs and a really small bullhead or stone loach don't really know as it was v. Tiny. The siphons were still running but there was so little water downstream the eels had to make a bit of an amphibious assault up the beach to get at the trap. Dave made a bit of a channel to help out.
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 26, 2015 7:32 am
Chaps wanted to check if anyone is heading deon Sat am?
http://Rivertac.org
Ed Randall
Male Posts : 3224
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 26, 2015 8:19 am
I will try to get down
TAC Secretary
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 26, 2015 8:32 am
Okay thanks mate, let me know if you are, I cant get over Saturday, so would have to be Sunday at best, or I will go on the way home tonight which maybe better.
If there is anyone who has not been involved and would like to, please let us know
This is our 4th year looking after the Molesey trap and its incredibly rewarding helping to monitor the progress of Eels up the Thames and helping them on their way upstream. Smile
http://Rivertac.org
patrick barker
PostSubject: Re: Eel Trap Results 2015 !   Fri Jun 26, 2015 4:55 pm
Yeah I'm going down there fishing so will see you there Ed.
Ed Randall
Male Posts : 3224
PostSubject: Re: Eel Trap Results 2015 !   Sat Jun 27, 2015 8:14 am
See you there a bit after 10am.
TAC Secretary
Ed Randall
Male Posts : 3224
PostSubject: Re: Eel Trap Results 2015 !   Sat Jun 27, 2015 5:34 pm
Today's results - 14 eels
TAC Secretary
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Mon Jun 29, 2015 8:04 am
Nice work chaps
We 100% need midweek checks as they are going to roast in that trap. I will try tomorrow but have flowershow parking challenges , then we should lalso be checking Thursday, and may ask Joe is no one is about, but is a work day of course for us all.
http://Rivertac.org
Neil Depledge
Male Posts : 721
PostSubject: Re: Eel Trap Results 2015 !   Mon Jun 29, 2015 9:29 am
I could do Thursday Dave.
http://www.depledge.me.uk
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Mon Jun 29, 2015 9:35 am
Superb yes please Neil, thank you.
http://Rivertac.org
Neil Depledge
Male Posts : 721
PostSubject: Re: Eel Trap Results 2015 !   Thu Jul 02, 2015 11:02 am
I've just queued for 10 mins in traffic trying to get to Sunbury Cross roundabout and got nowhere. It appears that it is solid traffic all the way to Hampton as it's the flower show. Can anyone get there from the other way?
Edited coz of stupid small keyboard on mobile Smile
David Harvey
Male Posts : 5381
PostSubject: Re: Eel Trap Results 2015 !   Fri Jul 03, 2015 7:40 am
Sorry Neil, sounds a nightmare.
Not sure if you abandoned it or not but I would have, bloody flower show, arghh.
I will try later as cant do tomorrow, hopefully mid afternoon will be Ok....
http://Rivertac.org
Sponsored content
Back to top
Page 3 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
 Similar topics
» Results 2015 World Judo Kata Championships - Amsterdam
» Herb Hedemann 1600m invitational
» Run & Ride Cannock Chase Winter Classic MTB 2015 Sun 1st March
» Vegas Cup 2015
Permissions in this forum:You cannot reply to topics in this forum
Thames Anglers' Conservancy Members Forum :: Open Section :: Conservation Issues :: Eel Monitoring-
Jump to:
